Hydraulic oil question for you guys
   / Hydraulic oil question for you guys #1
sportbikerider78
2009 Club Cadet Yanmar EX2900
Question for you guys..I have a Yanmar EX2900 with a hydro transmission and front end loader. 330 hrs.
I did my 300hr service on it this past weekend and picked up vp racing lubricants ultra j20a. I neglected to read the fine print at Tractor Supply and it says for use in older pre 1990 tractors. Mine is a 2008.
Yanmar recommends TF500 and that is a J20A from the pictures I have see of the actual oil containers.
Thanks for the help. If I have to drain it, I will.
   / Hydraulic oil question for you guys #2
It's hard to find a good transhydraulic oil. Not nearly as easy as a quality motor oil. Expect that the price will be typically a little over $50 for a 2.5 gallon container.
I run John Deere HyGard Low Viscosity (winter) trans/hydraulic oil or sometimes I'll run Kubota SUDT2. Both of those are good for just about anything and they have the advantage of flowing well when cold. That's when I want the oil to be at its best to protect the hydraulic pumps, wet brakes, and especially the hydro transmission.
   / Hydraulic oil question for you guys #3
attached is something I found that shows compatibility with TF500. I run Shell HD from TSC, same as Donax TD, in my YT359C, no problems.
Thanks for the post. I found that information the other day before I bought the oil.
I guess the part I'm confused about is if the TF500 is a J20A, is there any harm in keeping it?
And if the container itself says J20A, why do none of those cross over sheets list a J20A oil?
Anyone know what viscosity the TF500 is?
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
