hydraulic oil in crankcase
   / hydraulic oil in crankcase #1
Ric27
yanmar
I have a early 90's md 1600 Yanmar. a squalling sound suddenly developed upon starting. checked oil, crank case full to top with hydraulic fluid. Please, any ideas as were to start look for the cause and solution.
   / hydraulic oil in crankcase #2
If the shaft seal on your hydraulic pump develops a leak the usual result is an overfilled crankcase. You may be able to replace the seal, have the pump rebuilt in a hydraulic shop, or replace the pump. The squeal may be the sick pump complaining or it may be something else entirely.
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2 Chains and 4 Binders (A51573)
2 Chains and 4...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
