Oil & Fuel Hydraulic oil help
   / Hydraulic oil help #1
Strummer
Bronze Member
Strummer1%
Any substitute oil for the G134? My local dealer is now a little over an hour drive . Will be going in my power steering for my 2008 TC-40A
   / Hydraulic oil help #2
A Fleet Farm, any farm store, and some auto parts stores like Napa should have a universal tractor trans hydraulic fluid compatible with 134.
If you want something cold weather, amsoil has fn200 compatible and ships.
   / Hydraulic oil help #3
I have used, Traveler brand Universal Hyd oil from Tractor Supply. It specs out for Ford 134 oil also among many others for the last 15 years for my Ford 1700. I have not had any issues. It is basically used for transmission and 3 point lift and no loader.
   / Hydraulic oil help #4
Rotella tractor HD. Most people I know trust rotella in their engines, Their hydraulic oil seems to do well in my tractor as well.
   / Hydraulic oil help #5
For that tractor the power steering is it's own system with no wet brakes or clutches like the hydraulics/ trans. So really the fluid dosnt matter. How ever for any machine with wet clutches and brakes use the factory oil. It's not worth the $$ savings or lack there of in the long run.
