Hydraulic oil for B275 International
   / Hydraulic oil for B275 International #1
Robert Howland
B275 International
I changed the hydraulic fluid a couple of years ago in my B275 and it started leaking around the lift/lower lever shaft. I finally found the manual for the B275 and it calls for regular SAE 20 motor oil for the hydraulic system. Would this have caused the leak or was it just coincidence.
I guess i'll have to change the O-Ring to stop the leak. Should I refill with Motor Oil?
Any comments would be appreciated.
   / Hydraulic oil for B275 International #2
I'm not 100% sure, but I don't think that is hydraulic oil leaking that is likely gear oil on the B275.
No, it's coming right out of the lever shaft, located just below the tractor seat. I can see the drops.
   / Hydraulic oil for B275 International #4
Hydraulic oil in the 3point and 80w90 in the gearbox/diff/finaldrives
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
Ford F450 Bucket Truck with Altec AT200A Boom (A55218)
Ford F450 Bucket...
2012 JOHN DEERE 160G LC EXCAVATOR (A52705)
2012 JOHN DEERE...
