Oil & Fuel Hydraulic oil change question
   / Hydraulic oil change question #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
So here it is, I crawl underneath my 3320 today to start my first Hydro filter and oil change and low and behold, my Woods backhoe sub frame is about 1/2 an inch in front of the filter cover. It comes across at an angle and I think I can get at the cap screws holding the cover in place but I can only come straight out abot 1/2 inch and then I would have to pull it off the rest of the way at an angle. I spent about an hour on the JD parts site but could not find the cover to see its shape. I also am confused about the suction line that comes off the side of the cover. Because of the subframe in the way, I cannot figure out how to seperate it from the cover. The issue is that to remove that side of the subframe, I am looking at several hours of work.
I APPRECITE AND WELCOME ANY ADVICE.....
   / Hydraulic oil change question #2
Sorry to hear that. Did you get the tractor/BH from the same dealer at the same time?
The tractor and backhoe were bought as a package.
I just found a post on changing the filter and it sounds as though the filter cap just spins off. If that is the case, I may just have to slide the filter out past the subframe.
   / Hydraulic oil change question #5
Did mine last week (3520( . The filter cover just screws off about 1/2 ". The filter is long though 10" so that subframe might be a issue . I would consider fabing up a ifferent bracket for ease of accesability . Yes I know it's not often unless you are a commercial guy but to me if something is hard to get to it because of a bracket it gets recomfigured. Sotty for my spelling glasses are out in the barn.
Hey, hoddykubody, thanks for the info and about the glasses in the barn, gotta love it.
Bob
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
Sterling T/A Ox...
2017 RAM 2500 (A58214)
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2016 Chevrolet Tahoe SUV (A55973)
2016 Chevrolet...
