Hydraulic oil change on a New Holland T1510 HST
   / Hydraulic oil change on a New Holland T1510 HST #1
Heeb
T1510 NH
Does anyone know how many drain plugs for changing hydraulic oil. Manuel transmission model has 3. I can find only one for my HST model. It is not diagramed in owners manual.
Thanks
Is the 4wd drop box for the front axle that you fill through the yellow dip stick on top of front axle?
   / Hydraulic oil change on a New Holland T1510 HST #4
No, my mistake. The model does not have a drop box attached to the rear axle housing. You are only looking for two drain plugs for the transmission/hydraulics. One at the bottom of the transmission and one at the bottom of the rear axle center section. Front axle oil change is a separate operation outside this discussion.
Do you have an operator manual?
Yes I have the manual. The only diagram is for a manual transmission not HST
And I already have the front axle done along with the 2 front wheel final drives
2021 JOHN DEERE 2032R TRACTOR LOADER BACKHOE 4X4 (A51247)
2021 JOHN DEERE...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
New Holland Hay Rake (A51573)
New Holland Hay...
