Hydraulic oil change on a New Holland T1510 HST
   / Hydraulic oil change on a New Holland T1510 HST #1
Heeb
T1510 NH
Does anyone know how many drain plugs for changing hydraulic oil. Manuel transmission model has 3. I can find only one for my HST model. It is not diagramed in owners manual.
Is the 4wd drop box for the front axle that you fill through the yellow dip stick on top of front axle?
   / Hydraulic oil change on a New Holland T1510 HST #4
No, my mistake. The model does not have a drop box attached to the rear axle housing. You are only looking for two drain plugs for the transmission/hydraulics. One at the bottom of the transmission and one at the bottom of the rear axle center section. Front axle oil change is a separate operation outside this discussion.
Do you have an operator manual?
Yes I have the manual. The only diagram is for a manual transmission not HST
And I already have the front axle done along with the 2 front wheel final drives
Hustler Raptor Limited Zero Turn Mower (A51573)
Hustler Raptor...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
2025 New/Unused Wolverine Mini Ripper (A51573)
2025 New/Unused...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
Skid steer auger plate (A50322)
Skid steer auger...
JOHN DEERE 8245R LOT NUMBER 270 (A53084)
JOHN DEERE 8245R...
