Hydraulic Oil Change on 4310
   / Hydraulic Oil Change on 4310 #1
dfeck
Western, NY
Kubota B3200
I'm about to do, for the first time, a hydraulic oil change on my 4310. Is there anything special I need to do to drain the oil from the lines? I have a front loader and was wondering if there's a need to drain the lines. Also, the manual says to remove the suction screen and clean it. I assume this is necessary? Any other special tips for doing this?
Thanks,
Doug
   / Hydraulic Oil Change on 4310 #2
Just follow the book. You don't need to drain all the lines, unless there has been gross contamination. Even then you flush, not drain.
Yes, the suction screen has to be pulled, pay attention to what is trapped on it.
I found a large drain pan was useful, just make certain it will hold the capacity of your sump. Once you start there is no going back, and finding out that you can only hold 1/2 the fluid is a messy proposition.
Have fun.
   / Hydraulic Oil Change on 4310 #3
Good Luck and please post your experiences.
   / Hydraulic Oil Change on 4310 #4
I bought one of those under bed storage containers made by Rubbermaid or Sterilite for this purpose. I couldn't come up with anything else that would hold multiple gallons yet be short enough to fit under the tractor.
   / Hydraulic Oil Change on 4310 #5
15 gallon drain pan. Rubbermaid RUB RCP1732GRA - Palletote Box Drain Pan 15gal 23.5"X19.5"X13"
I own 4 of these and love them. 58 quart drain pan. Blitz UNM 42008 - 58 Quart drain pan
   / Hydraulic Oil Change on 4310 #7
Having worked on trucks that hold 40+ quarts of oil led me to buy them. There nice because once you fill it with oil you can put the plugs in and carry it around and not have to wory about spilling anything. They also have wheels built into the back end of it so you can pick it up by the pour spout and pull it around.
   / Hydraulic Oil Change on 4310 #8
I was gonna ask how you were moving them around, but I got my answer from your recent post.
2016 Chevrolet Cruze Limited Sedan (A55758)
2016 Chevrolet...
2002 Wacker RD11A Tandem Smooth Drum Roller (A55851)
2002 Wacker RD11A...
2011 CATERPILLAR D7E HI-TRACK CRAWLER DOZER (A52707)
2011 CATERPILLAR...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2005 Chevrolet Impala Sedan (A55758)
2005 Chevrolet...
