Hydraulic oil alternative BX
   / Hydraulic oil alternative BX #1
acethunder
Morden, MB
Kubota BX2670
What oil do you use for the hydraulics other than udt?
   / Hydraulic oil alternative BX #2
My neighbor was selling an extra b7800 he had that had a problem, sitting outside for 8 years, I brought over a new battery and 5 gallon of tractor supply Travelers hyd/trans fluid filled it up from mt and fired it up and drove it to my house and been using as is for the last 2.5 years. That's the way I am rolling and it kept my old Ford tractor going for over 25 years. I will get the haters but time will tell, I wont be here in another 25 years.
   / Hydraulic oil alternative BX #3
I’ve been using Valvoline Unitrac in my Kubota instead of UDT. Works great, no issues, and it’s way cheaper.
   / Hydraulic oil alternative BX #4
If you have the HST transmission UDT is strongly recommended. If you have any other transmission I suspect any good grade of hydraulic oil would be fine.
   / Hydraulic oil alternative BX #5
I just changed the oil in my BX24. I am somewhat superstitious so I went with the Kubota brand UDT. Total capacity is a little over 3 gallons. I bought a 2.5 gallon jug and the had to go back for a gallon (just to be sure) Total bill was around $110. For me that is cheap insurance. I just don't want to risk it to save a few dollars.
As a side note, I read the manual and knew the capacity was listed as 3.1 gallons. I had a little left in a gallon jug. So I thought with the 2.5 gallon jug, the leftover in my other jug and the fluid left in the lines and cylinders, I would have enough. That brought the level up to the very bottom of the range on the dipstick. (DOH!) Hence, I had to get another gallon to top off. In reality a quart probably would have been enough, but I didn't want to make another 20 mile trip to the dealer.
Doug in SW IA
   / Hydraulic oil alternative BX #6
Penny wise, pound foolish...an old expression I often fall back on...LOL...showing my age I suppose...
   / Hydraulic oil alternative BX #7
Super UDT is what I used at $30 a gallon???
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
(6) Goodyear 8.25 R20 Tires (A51573)
(6) Goodyear 8.25...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
