Hydraulic oil alternative BX
   / Hydraulic oil alternative BX #1
acethunder
Morden, MB
Kubota BX2670
What oil do you use for the hydraulics other than udt?
   / Hydraulic oil alternative BX #2
My neighbor was selling an extra b7800 he had that had a problem, sitting outside for 8 years, I brought over a new battery and 5 gallon of tractor supply Travelers hyd/trans fluid filled it up from mt and fired it up and drove it to my house and been using as is for the last 2.5 years. That's the way I am rolling and it kept my old Ford tractor going for over 25 years. I will get the haters but time will tell, I wont be here in another 25 years.
   / Hydraulic oil alternative BX #3
I’ve been using Valvoline Unitrac in my Kubota instead of UDT. Works great, no issues, and it’s way cheaper.
   / Hydraulic oil alternative BX #4
If you have the HST transmission UDT is strongly recommended. If you have any other transmission I suspect any good grade of hydraulic oil would be fine.
   / Hydraulic oil alternative BX #5
I just changed the oil in my BX24. I am somewhat superstitious so I went with the Kubota brand UDT. Total capacity is a little over 3 gallons. I bought a 2.5 gallon jug and the had to go back for a gallon (just to be sure) Total bill was around $110. For me that is cheap insurance. I just don't want to risk it to save a few dollars.
As a side note, I read the manual and knew the capacity was listed as 3.1 gallons. I had a little left in a gallon jug. So I thought with the 2.5 gallon jug, the leftover in my other jug and the fluid left in the lines and cylinders, I would have enough. That brought the level up to the very bottom of the range on the dipstick. (DOH!) Hence, I had to get another gallon to top off. In reality a quart probably would have been enough, but I didn't want to make another 20 mile trip to the dealer.
Doug in SW IA
   / Hydraulic oil alternative BX #6
Penny wise, pound foolish...an old expression I often fall back on...LOL...showing my age I suppose...
   / Hydraulic oil alternative BX #7
Super UDT is what I used at $30 a gallon???
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
