hydraulic noise
/ hydraulic noise #1
apatche1964
john deere 955
I have a terex hr16 mini trackhoe and sometimes there is a prety loud noise coming from the hydraulic pump and then it will stop. It is full of oil and seems to work ok
/ hydraulic noise #2
Hose or cylinder leaks? Is it a chattering sound? Does it occur when you're using the controls? Any places where air could be getting into the system?
/ hydraulic noise #3
To rule out suction side, clean/alt remove suction strainer, breather and check suction hose for inside collapsing alt kinks....noise might be cavitation.....
/ hydraulic noise #4
Does it happen when you first start-up...then go away?.....If so then it could be a shaft seal leak on the main pump (sucking air or loosing prime while sitting and not running)
/ hydraulic noise
it seems to do it when i am turning the machine on the table Thanks for the replys
/ hydraulic noise
It's me again with the growling hydraulic system on my terex excavator. i've determined that it starts doing it after it gets hot' I'm looking for a replacement filter but can't find one also i'm thinking of changing all the fluid since it's had various mixtures in it any other suggestions would be appreciated thanks it's a terex hr16
/ hydraulic noise #7
That noise you are hearing from the pump is probably cavitation. and the sound is caused by the bubbles in the fluid collapsing, and this can erode the metal in the pump.
If that pump is cavitating to much, you will soon need a new pump.
Are you using manufacturer recommended fluid? Check for restriction on the suction hose. Check strainer in tank if any.
It would not cost to much to have someone put a flow meter on the system and verify normal or abnormal condition.
2020 Nissan Murano SUV (A66738)
2020 Nissan Murano...
2023 Norden SQ90 Hydraulic Bale Squeeze Tractor Attachment (A66734)
2023 Norden SQ90...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2009 CHEVROLET SILVERADO 3500 TOW TRUCK (A65057)
2009 CHEVROLET...
FMF 3pt 5' V Plow (A64912)
FMF 3pt 5' V Plow...
