Hydraulic mystery
   / Hydraulic mystery #1
mtjag
Westcliffe, CO
Montana 2740
I have a 2008 Montana 2740. A few days ago while snow plowing with my bucket down, the pump started a shrilling sound that went away after I stopped and idled down the engine. Afterwards, I noticed that my bucket would move up and down, but it would not tilt the bucket. I left if a couple of days and tried it again yesterday and the same thing. All the hydraulics work except for the tilting of the bucket. Is this a valve problem or maybe the controller for the bucket, even though it lifts the bucket?
   / Hydraulic mystery #2
Check the quick connects for the bucket tilt cylinders (take them off and put them back on). They can some just loose enough to not work properly.
Aaron Z
   / Hydraulic mystery
Hey thanks much for the quick reply. I will go out and try that now.
Thanks again.
   / Hydraulic mystery #4
How'd it work? Also, check your fluid level. I had a leak from the tranny on my old massey, and didn't check the fluid for a couple days and got a similar sound from the pump.
   / Hydraulic mystery #5
Pumps will squeal when they suck air. When is the last time you replaced the hydraulic filter? Also check the fluid level. if you have a mid-mount valve make sure it's connected correctly and all snugged down.
   / Hydraulic mystery
Well I checked the discconnects, and checked the fluid level which was about two quarts low. Fill it up and the bucket will raise and lower, but not tilt or rotate....so I suppose it's the controller?
   / Hydraulic mystery #7
Try switching the lift and tilt connections. That will allow you to verify that the tilt part works but the valve is bad.
Aaron Z
   / Hydraulic mystery #8
Hmmm interesting....
How is your FEL plumbed? Is it connected to a remote valve? Maybe two? If so, is your remote valve lever in the correct position? What happens when you try to dump/curl the bucket? Does the valve make any noise at all? Do the cylinders try to move? Running a little low on fluid should not hurt your valves. Are you sure there isn't anything keeping your bucket from moving, such as a wedged rock? This is a mystery...
   / Hydraulic mystery #9
Has anyone taken any pressure readings. Might provide a clue.
   / Hydraulic mystery
Aaron Z
OK, I switched the connections and the tilt controls lifted the bucket, but the lift controls didn't tilt the bucket. I switched them back and the it's the same as it was...lift works, tilt doesn't. That's really strange.:confused:
2013John Deere 244J (A47477)
2013John Deere...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2012 Club Car Electric Cart (A53424)
2012 Club Car...
2011 TROXELL COMPANY 130BBL VACUUM TRAILER (A53843)
2011 TROXELL...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
