Hydraulic motor specs
   / Hydraulic motor specs #1
Truckerdad
Hello all..any know what the minimum reguirements/specs would be for a hydraulic motor that would be capable of powering a 38"(2 blade) or 48" (3 blade) mowing deck? Thanks
   / Hydraulic motor specs #2
I believe the hyd motors on the Power-Tracs 48 in deck, are 3 cu in. If true, at 8 GPM's, the rpm will be 616, and the torque at 3000 psi will be 1433 in lbs.
I am not sure of the pulley ratio, but if known, you could work out blade tip speed.
OK thanks a bunch...it's a good place to start. Any and all info from any and everyone is appreciated!
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
2012 Ram 4500 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ram 4500...
Bobcat 15 Skidloader PHD (A50774)
Bobcat 15...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2014 BMW 328I (A50120)
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
