Hydraulic motor selection and sizing
/ Hydraulic motor selection and sizing #1
67Berg
Michigan
2020 LS XG3135H
I was hoping someone could answer a few questions. I have a LS XG3135H, I recently picked up a snowblower, older but great shape except no manual chute rotator device. Planning on adding a hydraulic motor with chain and sprockets to rotate the chute. Question: what concerns should I have on selecting a Hydro motor, like psi, rpm and flow? Tractor Supply has a motor by Chief. Motor specs - 23.6 CID, SAE 10 ports, 150 RPM, 3,850 torque and operating PSI is 1450.
Would appreciate some advice and education. I know it won't take hardly any torque, but I was hoping to rotate it fairly slow. Thanks
/ Hydraulic motor selection and sizing #2
You can install flow controls to limit motor speed and use a much smaller motor. Hard part is guessing how much torque is required to turn that chute while in use.
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
2013 JOHN DEERE 310SK BACKHOE (A62129)
2013 JOHN DEERE...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A61567)
2018 Roadtec...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2006 Link Belt HTC-8675 75 Ton Hydraulic Truck Crane (A60352)
2006 Link Belt...
