Hydraulic Motor questions... 101...
   / Hydraulic Motor questions... 101... #11
Junkman I have a Woods snowblower with a manual chute. However my exploded parts diagram shows how the hydraulic motor can be used to drive it. it also calls for one 3/8 inch swivel flow restrictor 1/32" hole size to slow the hyd. motor down. If you PM me a fax number I will be more than happy to fax these diagrams to you ASAP. Possibly you can use one or more of the ideas on your blower.
   / Hydraulic Motor questions... 101... #12
My 2 cents,
I obtained an electric wheelchair motor for $50 (Cdn) and attached a 3" sprocket.
The motor is very much like a boston gear 90deg reduction gear motor only in 12 or 24vdc.
I then literally wrapped a matching chain around the chute attaching it to a welded anchor point that had 2 holes drilled to accept the chain ends.
This bracket or tab I located such that I could get my desired left /right limits, ie with chute blowing about 30 deg fwd on left side when the tab was at near travel limit.
I also used a threaded rod (short bolt) to serve as an adjuster.
I ran this setup all last winter with no problems at all.
The wheel chair motor is a worm gear drive rig designed for slow speed and oodles of torque.
I found that with the chute (chain and sprocket) all iced up there was enough power to break it loose easily.
Up here folks also use these drive motors to roll/retract dump truck tarps as well.
Being a DC motor wireing is a simple rocker switch with center off and spring loaded both sides.(DPDT)=$10.00
Total traversing from side to side is about 15-20 seconds and with a rocker switch you can place it about anywhere you wish unlike a hydraulic valve.
Oh, and over the top of the sprocket I made a 4" poly washer to prevent crap from entering the sprocket. Luckily the output shaft had a threaded hole in the end to facilitate this.
   / Hydraulic Motor questions... 101... #13
Cool, Piloon. Any chance of a photo? I salvaged an automotive electric window operator motor for my blower. I hope that works OK, but I dont know how much torque it has.
   / Hydraulic Motor questions... 101... #14
The window motor should work if you can attach the sproket to it ok. You might have to gear it a bit slower with sprockets, but it would just move slower. With a good enough gear ratio or a long enough lever you can move almost anything, just slower /forums/images/graemlins/smile.gif
Ben
   / Hydraulic Motor questions... 101... #15
You might consider trying a wiper motor. It has right angle gear reduction and enough limited torque to prevent the stopping problem. Available everywhere for a buck or two.
PALLET OF MISC PLYWOOD (A58374)
PALLET OF MISC...
2006 Dodge Ram Pickup Pickup Truck, VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
