Hydraulic motor help ?
   / Hydraulic motor help ? #1
jesker
mosinee wi
bobcat
Hello everyone, I need some help selecting a hydraulic motor to power a winch. The winch i have is a Rhino 8000lb worm gear winch. It has a rated line pull off 8000lbs, 29:1 gear ratio, and a max input speed of 1000rpm and 4.125" diameter hub. I plan on running this whinch with the aux. hydraulics on my Bobcat 450 tractor (50hp) The tractor has a hyd flow of 9.5 gpm. I would like the motor to have around 1000rpms so I have the proper line speed. If my caculations are correct at 1000 rpm I will have a line speed of 40.6 fpm with .38 cable on first wrap on drum. I also could use a motor with 500 rpm and just use sprockets and chain to get the proper speed. I would like the motor to have enough power to get close to the 8000lb of pull. I plan on using this for a logging type winch project. Will my tractor have enough hyd flow (power) to run a motor for this? Any help would be great.
Thanks Jason
Thanks for the help J.J. thats what i was looking for :thumbsup:
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2015 CASE 580N (A47477)
2015 CASE 580N...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
