Hydraulic motor help ?
   / Hydraulic motor help ? #1
jesker
mosinee wi
bobcat
Hello everyone, I need some help selecting a hydraulic motor to power a winch. The winch i have is a Rhino 8000lb worm gear winch. It has a rated line pull off 8000lbs, 29:1 gear ratio, and a max input speed of 1000rpm and 4.125" diameter hub. I plan on running this whinch with the aux. hydraulics on my Bobcat 450 tractor (50hp) The tractor has a hyd flow of 9.5 gpm. I would like the motor to have around 1000rpms so I have the proper line speed. If my caculations are correct at 1000 rpm I will have a line speed of 40.6 fpm with .38 cable on first wrap on drum. I also could use a motor with 500 rpm and just use sprockets and chain to get the proper speed. I would like the motor to have enough power to get close to the 8000lb of pull. I plan on using this for a logging type winch project. Will my tractor have enough hyd flow (power) to run a motor for this? Any help would be great.
Thanks Jason
Thanks for the help J.J. thats what i was looking for :thumbsup:
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
2019 Allmand Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
