Hydraulic Lockout Valve-X585
   / Hydraulic Lockout Valve-X585 #1
Steadite
North East PA
John Deere x585
Have a question about the "hyd. cyl. lockout valve" that gets mounted behind the SCV. Mine doesn't seem to change anything whether it's open or closed...in other words, when I use the bucket curl, the 3pt hitch (ballast box) and mower deck go up and down (maybe a little slower with valve closed). Dealer doesn't seem to know anything about it and says it's normal (the dealer is another story---doesn't always pay to go with the lowest price!!!). What is everyone else's experience with that valve? Is there another/better way?
On a related subject, I found reference to something called a "regenerative bucket kit" (P/N BM20911) which is supposed to "improve bucket cycle times". Anybody know anything about this? How much $, how well does it work? Again....dealer clueless.
   / Hydraulic Lockout Valve-X585 #2
Is the valve installed on the correct circuit? Is the valve fully closing? The lockout works on my 445, its a pretty simple thing, I installed it myself.
Thanks for the response. I'm sure it's installed right...only 1 way it can go (I put it in myself too). Just so I'm clear, on your machine with the lockout valve closed, the mower deck cylinder doesn't operate at all?
   / Hydraulic Lockout Valve-X585 #4
I know this is an old thread, but I think it is relative to a problem I am having with my JD 455. My 3-point hitch keeps dropping with the ballast box on it when I curl the bucket and doesn't come up again. At first, I would loosen and then tighten the lockout valve and that seemed to help a bit, but after a while that started doing nothing too. It has rendered use of the bucket impossible. Any thoughts? I really need some help on this. Thanks, in advance.
   / Hydraulic Lockout Valve-X585 #5
DMM, is does sound like your lockout valve is damaged - the hitch on my 455 does not move at all when it is locked. Can't you just adjust the downstop on the 3-point to take care of this temporarily?
Tim
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2002 Chevrolet Silverado 2500 4X4 Pickup Truck, VIN # 1GCHK29UX2Z216239 (A51572)
2002 Chevrolet...
