Backhoe HYDRAULIC LINES ON BT900 BACKHOE
   / HYDRAULIC LINES ON BT900 BACKHOE #1
BOTAL35
MONTGOMERY , AL
95 KUBOTA L35
NEED HELP! NEED TO REPLACE HYDRAULIC HOSE ON BACKHOE. IT IS THE LINE THAT RUNS TO THE DIPPERSTICK CYLINDER. THE LINE RUNS THROUGH THE SWINGFRAME WITH 5 OTHER LINES. THIS IS A VERY TIGHT SPOT PLUS IT IS IN A PROTECTIVE SOCK. WHAT IS THE TRICK TO PULL THE LINE THROUGH THE SOCK? THERE IS 6 LINES IN THERE. I GET HALFWAY THRU AND IT GETS STUCK. ANY SUGGESTIONS?
   / HYDRAULIC LINES ON BT900 BACKHOE #2
Do you have a fish tape? You could jiggle the fish tape through........ then ductape the hydraulic line to the fish tape and pull it back through.
DID THAT WITH ELECTRIC FENCE WIRE. JUST WORRIED WHEN I PULL LINE OUT WILL NOT BE ABLE TO PULL NEW HOSE BACK THROUGH SUCH A TIGHT SPOT.
   / HYDRAULIC LINES ON BT900 BACKHOE #4
WHY ARE YOU SHOUTING?!
There is probably a zip tie or two around the protective sock somewhere in the middle, which is causing the coupler end to hang up. You may need to disconnect all of the lines and pull the entire sock with all 6 lines out so that you can open up the zip tie(s) and feed the new line through, then feed the entire bunch back up through the swingframe.
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2020 Chevrolet Silverado 3500 HD 4X4 Service Truck (A52377)
2020 Chevrolet...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
