Backhoe HYDRAULIC LINES ON BT900 BACKHOE
   / HYDRAULIC LINES ON BT900 BACKHOE #1
BOTAL35
MONTGOMERY , AL
95 KUBOTA L35
NEED HELP! NEED TO REPLACE HYDRAULIC HOSE ON BACKHOE. IT IS THE LINE THAT RUNS TO THE DIPPERSTICK CYLINDER. THE LINE RUNS THROUGH THE SWINGFRAME WITH 5 OTHER LINES. THIS IS A VERY TIGHT SPOT PLUS IT IS IN A PROTECTIVE SOCK. WHAT IS THE TRICK TO PULL THE LINE THROUGH THE SOCK? THERE IS 6 LINES IN THERE. I GET HALFWAY THRU AND IT GETS STUCK. ANY SUGGESTIONS?
   / HYDRAULIC LINES ON BT900 BACKHOE #2
Do you have a fish tape? You could jiggle the fish tape through........ then ductape the hydraulic line to the fish tape and pull it back through.
DID THAT WITH ELECTRIC FENCE WIRE. JUST WORRIED WHEN I PULL LINE OUT WILL NOT BE ABLE TO PULL NEW HOSE BACK THROUGH SUCH A TIGHT SPOT.
   / HYDRAULIC LINES ON BT900 BACKHOE #4
WHY ARE YOU SHOUTING?!
There is probably a zip tie or two around the protective sock somewhere in the middle, which is causing the coupler end to hang up. You may need to disconnect all of the lines and pull the entire sock with all 6 lines out so that you can open up the zip tie(s) and feed the new line through, then feed the entire bunch back up through the swingframe.
2006 Poly-Coat Tanker Trailer (TITLE) (A50774)
2006 Poly-Coat...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2024 Bobcat E35 Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Bobcat E35...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
CFG Industrial MX12RX (A50121)
CFG Industrial...
Tennant 800 Ride-On Street Sweeper (A50322)
Tennant 800...
