hydraulic lines and connections
   / hydraulic lines and connections #1
john m
Inverness,FL
cub cadet 149
well here it is, i have almost finished my loader project, but i need to run the lines. i have a haldex 4-8 GPM pump 1200 PSI and running 2 inch bore cylinders. the pump has 7/8 ORB fittings and i need to run up to my 2 spool cesna valve off of a JD 318 those are 37- JIC fittings. i would like to use the reusable fittings from discount hyd. hose, so i can make my own hoses for everything, but was wondering how well those work. i read a few other sites and people like them. i tried to call DHH but being sunday they were closed. i still need to weld up a fluid tank and weld fittings on that. but wanted to wait until i knew what i could do for the plumbing. i wanted to run 3/8 NPT lines to the cylinders with 37 jic fittings at the valve as they are already there. and 3/4 lines for the pump. thanks John
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
Kubota RTV500 (A47384)
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
2013 Buick Enclave SUV (A51694)
2013 Buick Enclave...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
24008 (A53422)
24008 (A53422)
