hydraulic lines and connections
   / hydraulic lines and connections #1
john m
Inverness,FL
cub cadet 149
well here it is, i have almost finished my loader project, but i need to run the lines. i have a haldex 4-8 GPM pump 1200 PSI and running 2 inch bore cylinders. the pump has 7/8 ORB fittings and i need to run up to my 2 spool cesna valve off of a JD 318 those are 37- JIC fittings. i would like to use the reusable fittings from discount hyd. hose, so i can make my own hoses for everything, but was wondering how well those work. i read a few other sites and people like them. i tried to call DHH but being sunday they were closed. i still need to weld up a fluid tank and weld fittings on that. but wanted to wait until i knew what i could do for the plumbing. i wanted to run 3/8 NPT lines to the cylinders with 37 jic fittings at the valve as they are already there. and 3/4 lines for the pump. thanks John
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
