Hydraulic line protection.
   / Hydraulic line protection. #1
fish1552
Hinesville
Mahindra 4530
I own a 4530 and I do a bit of pushing vegetation/brush on occasion and I have had to replace the power steering line on the front left once before. I noticed the steering was a bit sloppy the other day and looked and once again, the power steering line is bent at a 45 degree angle.
I need to design a way to add a cover in front of this as the current design places them directly in front of the arm and almost in line with the front edge of the tractor - which is a bad design IMO. I am looking for an idea that could be removable for maintenance, but be sturdy enough to take a hit and keep protecting things. Maybe 1/4" steel plate or a piece of angle iron. Those lines run $81 each and I'd like to use that money elsewhere, like nice LED lights, attachments, etc.
Here is the current line. It's supposed to come straight out, bend up at 90 degrees (vertical), then curve back at 90 degrees, horizontal to the ground. When new, it lines up within maybe 1/8" of the front edge of the tractor in the bottom center of the Pic. Screenshot_20200514-112730_Messenger.jpg
   / Hydraulic line protection. #3
Can you swing a 90 deg fitting in the spot, in place of the straight? If so, replace the straight with it and come out with that, maybe a 90 deg hose end and replace the tube with a hose............Mike
   / Hydraulic line protection. #4
Mike is on what my 1st thoughts were as well. Replace all of that hard line with short pieces of hard line changing the angles to protect the connections and keep them as close as possible.
You should be able to have a line made anywhere that makes hydraulic lines. Take lots of photos and take the hard line with you. You may want to do a 90 degree elbow fitting at the pump ti keep it all really close. You could also put the new line in a sleeve or rubber hose to provide some additional protection.
I called the younger kid as he works at a hydraulic shop now but they only do hoses. He did send me a nunber for a company 50 miles down the road from hs shop that does hard line, but I like the idea of the softer hose instead. I'm definitely going to ask about a 90 degree for there.
I'm still going to try to mock up something to cover the area just in case to protect it a bit more. I just have to figure if I bolt it to the front edge of the body or maybe modify the shorter existing shield for the tie rods.
Thank you both for the great idea.
So the kid said he could get 2 90 elbows and then run a flexible hose from there that they can make in the shop. Problem is that it has been 2 weeks and he's not progressed on that. So I'm biting the bullet and ordering the replacement part for now, but will take the old line to find the elbows myself and have them ready for the next time. I know it will happen because it gets used for pushing brush but the bucket stays down. So it must be random branches popping up and hitting the line. Will post part numbers and stores when I get everything in case someone else needs them later as well.
   / Hydraulic line protection. #7
When I looked at a Mahindra last time, the hydraulic lines seemed to me like they were metric. Just a hint.
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
2018 Chevrolet Traverse LT SUV (A50324)
2018 Chevrolet...
2024 Icon I40L Electric Cart (A50324)
2024 Icon I40L...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
Commercial Trailer (A51692)
Commercial Trailer...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
