Hydraulic line fracture
   / Hydraulic line fracture #1
Evidence8489
I saw that i was getting a steady drip of hydraulic fluid from under the front of my dk45se.
I found that the half inch line that went from the filter
on the left side to the front of the tractor had a crack where the tab was welded on to connect it to the engine block.
There is no apparent damage from outside sources.
I am thinking that since this is hard mounted to the vibration producing part of the tractor, it cracked under the strain.
I believe that when this gets replaced that it should be rubber mounted to keep it from cracking in the future.
Am I on the right track:confused: ?
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
Lot (2) HD 10' Pipe Gates (A50515)
Lot (2) HD 10'...
2015 International 4400 Cab & Chassis (A47384)
2015 International...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
