Hydraulic line failed - need help
/ Hydraulic line failed - need help #1
G McCall
On my 1999 era Kubota M4800 tractor:
A hydraulic line connected to a tee inside the right bucket arm frame split open. The problem is I can' get a wrench on the connection to get the line off at the tee inside the frame arm. One end of the line was easy enough to remove but the connection inside the frame at the tee is impossible to get to. The tee in question is at the end of a hydraulic line run from the hand lever control for the bucket.
I think I may have to remove other lines that may allow the tee to slide out of the frame if that is possible but I am not sure.......
(If I made any sense with my description)
Anyone know how a line like I described is replaced ? :confused:
/ Hydraulic line failed - need help #2
I think you are on the right track.. loosen another line that will allow the T to have some slach.. then remove that fitting.. etc..
Check all the other lines out if they are the same age.. look for bulging, splitting and cracking into the wires.. weather checking on the rubber isn't a bad issue i fthe braid is intact and not rusty.
soundguy
2011 John Deere CX15 (A64911)
2011 John Deere...
Auger Bit (A64912)
Auger Bit (A64912)
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
Deere 317G (A64911)
Deere 317G (A64911)
