Hydraulic leak
/ Hydraulic leak #1
roadtrash
N. Mich
kubota
I have what appears to be a leak in my FEL pump on my 3010.After use I notice a little hydraulic oil on the floor, I cant pinpoint the leak but when I move my fingers around the bottom of the pump I get a little fluid.Is anyone aware of any particular problems with the pump? also how tough is it to replace the pump?. The fittings appear to be tight, is there something else I should be aware of.Thank you in advance.
/ Hydraulic leak #2
It would be best to locate exactly where the leak is coming from. It really hurts to buy parts that are not needed.
Wash the area down real good an dry it off to help in locating the problem.
Sellick S80 (A60462)
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
KMC 3386 (A64119)
KMC 3386 (A64119)
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
