Hydraulic Leak
   / Hydraulic Leak #1
jlbmi
Michigan
Kubota L3800
I have an L3800 that is leaking hydraulic fluid. It only does it when I use my wood splitter. It leaks from a hose under the seat. Is there something that I am doing wrong. When using the wood splitter, I attach a bungee cord to the hydraulic engagement lever and then use the controls on my splitter to operate the ram.
A fair amount of oil leaks from it when I use it.
   / Hydraulic Leak
Bumping any ideas?
   / Hydraulic Leak #3
There was a thread about this here a while back....Something to do with the type valve in the splitter..power beyond type??? Hopefully one of the knowledgeable contributors to that thread will jump in and help you out.
   / Hydraulic Leak #4
Are you sure it does not appear to leak from the breather tube (overflow tube)?
>Does the oil get hot when splitting wood?
>Can you pinpoint where the hose is leaking? At the thread? At the swivel (if so equipped)?
A photo of the leaking hose may go a long way to helping to solve the issue.
   / Hydraulic Leak #5
If I understand you are strapping or holding you remote open if this is correct you must have a open center valve on the wood splitter, when you are moving the splitter cylinder in or out oil is flowing when you release the directional valve on the splitter to neutral does the tractor change sounds at like when you bottom out the splitter?
If you hear the tractor sound as if it is under load your fluid is not flowing.
2006 Nissan Titan Crew Cab Pickup Truck (A50323)
2006 Nissan Titan...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
Cat TH407C Telehandler (A52748)
Cat TH407C...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
