hydraulic leak
/ hydraulic leak #1
jinmared
Goldendale,Wa
Jinma 354 fwd
My FEL bucket has a leak in one of the pistons that control the tilt forward or backward. Is there a test that I can run to identify which one it is?
Thanks, Jinmared
/ hydraulic leak #2
You can disconnect the hydraulic hose from one side cylinder and see . Think of it this way you have a cylinder with a piston in it pump fluid in the top shaft piston moves down fluid in the bottom is pushed out but if the piston is all the way out the only way fluid can come out leak around piston seal. Hope this makes cents
UNUSED FUTURE STB47 TELESCOPIC BOOM (A65055)
UNUSED FUTURE...
SHOP PRESS (A64278)
SHOP PRESS (A64278)
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A67147)
2001 FREIGHTLINER...
UNUSED PARBREAK GB232-79" HYD GRAPPLE BUCKET (A65055)
UNUSED PARBREAK...
2016 Scag Turf Tiger 72in Zero Turn Commercial Mower (A64553)
2016 Scag Turf...
UNUSED PARBREAK BT200 STUMP BUCKET (A65055)
UNUSED PARBREAK...
