hydraulic leak
/ hydraulic leak #1
jinmared
Bronze Member
Goldendale,Wa
Jinma 354 fwd
My FEL bucket has a leak in one of the pistons that control the tilt forward or backward. Is there a test that I can run to identify which one it is?
Thanks, Jinmared
/ hydraulic leak #2
You can disconnect the hydraulic hose from one side cylinder and see . Think of it this way you have a cylinder with a piston in it pump fluid in the top shaft piston moves down fluid in the bottom is pushed out but if the piston is all the way out the only way fluid can come out leak around piston seal. Hope this makes cents
2010 MACK CXU TRI-AXLE (A60736)
2010 MACK CXU...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2020 Deere 544L (A60462)
2020 Deere 544L...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
Large Metal Bull Smoker (A61569)
Large Metal Bull...
832749 (A61166)
832749 (A61166)
