Hydraulic leak under pedals NX 5010 HST
   / Hydraulic leak under pedals NX 5010 HST #12
Thanks. Any idea how quick shipping is?
Ask for Seth, he handles parts. Call early in the morning and he'll get them out that day (if in stock).
He has shipped parts for me from his source to my house for a straight fast delivery. So either way you'll get you parts as quickly as possible.
He's taken care of my filters when I get in a bind and they get here UPS fast.
On edit, rather then fill out the form just call up and ask to speak to Seth. He's their parts guru and will help you out. They know I'm 90 minutes away and are very considerate to help me and not make that drive if they can help out by phone. Confident they will take care of your needs.
If he is not there ask for Joseph or Jordan. They are the owners. Tell them where you are calling from and the help you need. They will get you the help you need.
Thanks for the info. Need to use the tractor this week.
   / Hydraulic leak under pedals NX 5010 HST #14
You probably have a closer dealer than Paige and could likely get them quicker from someplace local, but I've always found Jordan to be very responsive...and he's not the closest dealer to me. Folks at Hill Country Tractor are also pretty good to work with, just wound up buying the tractor from Paige because they had a good deal on what I wanted.
   / Hydraulic leak under pedals NX 5010 HST #15
Here is the link for your location.
Find a KIOTI Dealer | Kioti Tractors
fill in your zip code and see who is nearest that can provide your service.
well on second thought duh you have a Kioti so you know your dealer lol.....grayed haired moment here....
Justman777 and I both seem to have a good rapport with our dealer.
Hope your local dealer can provide the same type of service for you.
And most likely get your parts in for you quickly as well.
However, if there are any snags and you need a go to dealer; the folks at Paige will help you...
Update - Ordered the parts locally, was actually cheaper and same time frame. Got the hose and a new bulkhead fitting as the original was belled from over tightening. I ordered plastic spiral hose wrap (12' - $32 on amazon) to go around the 3 hoses that were close to frame. 1 1/2" ID was good size, not too lose or tight for 3 hoses. Will be ordering a length of 3/4 for use on single lines. Noticed that the quick coupler for the other side of the bulkhead fitting was allowing a loader hose to rub against the hood and wear the paint. Will address that too.
Attached a pics of the hose, the repair and the extra spiral wrap.
   / Hydraulic leak under pedals NX 5010 HST #17
Good stuff spiral wrap. Buys itself after the first blown hose you don't have.
I'm a big fan of nylon protective hose sleeves too, usually around $1 to $ 1.5 per foot. Provides a bit of chafe protection, but it also keeps the elements from breaking down and cracking the hose outer rubber layer, which would then allow the first braided layer to corrode, eventually destroying your hoses. Takes many years before you reap the benefits of this. But def worth it. have done all hoses on my dk54se and loader.
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
2013 RAM 4500 (A50323)
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51246)
2014 TAKEUCHI...
