Hydraulic Leak - Need suggestions
   / Hydraulic Leak - Need suggestions #1
pemad
Syracuse, New York
B7510 HST
I have a leak where one hose joins another. I have tried tightening the two together as much as I can and when the tractor applies a lot of Hydraulic pressure it still leaks. Any suggestion on what I can use to stop the leaky threads?
   / Hydraulic Leak - Need suggestions #2
<font color="blue"> ...I have a leak where one hose joins another...</font>
Take the hoses apart... replace the defective o-ring inside the one connector... tighten "appropriately"...
Thanks for the suggestion but there is no o-ring.
   / Hydraulic Leak - Need suggestions #4
<font color="blue"> ...no o-ring... </font>
Is it possible... was never installed?
or check the threads for "damage"... over tightening can do them in real quick...
Worse comes to worse... take both hoses off... have a hydraulics "pro" give it a once over... (or you can replace both hoses with "new" as a drastic measure)
... it's actually pretty basic stuff... perhaps you're overlooking/missing something simple... /forums/images/graemlins/crazy.gif
JohnMiller3 - is there any type of thread goop I can put on the threads? Like pipe dope?
   / Hydraulic Leak - Need suggestions #6
I would take them apart, clean them good and apply pipe sealant with teflon. It's a white paste and does an excellent job. Unlike teflon tape slivers of it won't get into your system.
When cleaning the threads be sure and swab out the female end after your through.
If all else fails, and you have enough slack, you can take the hoses to a hydraulic shop and have the ends replaced. They may only have to replace one of them to get a good seal.
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2016 INTERNATIONAL LF687 (INOPERABLE) (A53843)
2016 INTERNATIONAL...
John Dozer JD650 (A51691)
John Dozer JD650...
33ft Dovetail Flatbed Trailer (A53473)
33ft Dovetail...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
