Oil & Fuel Hydraulic Leak? MF-135
   / Hydraulic Leak? MF-135 #1
slhilbert
Noblesville IN
Massey Ferguson 135
You guys were so helpful with my last issue that I have come back looking to tap into more of your knowledge.
I have a decent leak coming from what I believe to be the hydraulic mechanism. When the PTO is engaged, especially when the External pump is on, I can see fluid coming out.
Attached is a picture of where the leak is occurring. I have circled the two "bolts" that the leak seems to be leaking out of.
Can I just tighten these down? I suspect one is some sort of filling cap bolt, is that accurate? What is it and how do I stop the leak?
Thanks!
Stuart
   / Hydraulic Leak? MF-135 #2
G'day slhilbert.
Lower the linkage to minimise the loss of oil ,remove the plug and replace the Dowty Seal,the dowty seal is a metal washer with a rubber insert.
happy Days.
Hutch.
JOHN DEERE LOT NUMBER 138 (A53084)
JOHN DEERE LOT...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
Toro Zero Turn (A50324)
Toro Zero Turn...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
