hydraulic leak JD345
   / hydraulic leak JD345 #1
telecom
Truxton,N.Y.
JD345
changed both inline and internal filters and refilled with hyd. fluid.
still leaks. any help please?
   / hydraulic leak JD345 #2
How does changing filters and oil help a leak? Where is it leaking?
If I knew where it was leaking I would have fixed it. changing the filters had nothing to do with the leak.
thanks for the help!
   / hydraulic leak JD345 #4
with your description I believe its leaking at the left front wheel. You really need to tell a little more about it,what area and how bad of a leak
   / hydraulic leak JD345 #5
Where do you think it might be leak? Just what is going on, does something drop or you seeing oil on the floor?
   / hydraulic leak JD345 #6
If you have oil on the floor, you should be able to tell where it is coming from.
If you are up to it, you can add some fluorescent dye in the tank and shine a black light on everything and you will see where fluid is leaking from.
   / hydraulic leak JD345 #7
Sorry, I cant help.
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
New Wolverine Push Blade (A53002)
New Wolverine Push...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
New Long Forks (A53002)
New Long Forks...
