Sep 15, 2015 / hydraulic leak JD345 #1 T telecom New member Joined Aug 9, 2013 Messages 2 Location Truxton,N.Y. Tractor JD345 changed both inline and internal filters and refilled with hyd. fluid. still leaks. any help please?
Sep 16, 2015 / hydraulic leak JD345 #2 L Leejohn Elite Member Joined Sep 16, 2007 Messages 4,049 Location Doniphan, Mo. Tractor Kubota L4240, B7800 & BX2660 How does changing filters and oil help a leak? Where is it leaking?
Sep 16, 2015 / hydraulic leak JD345 Thread Starter #3 OP T telecom New member Joined Aug 9, 2013 Messages 2 Location Truxton,N.Y. Tractor JD345 Leejohn said: How does changing filters and oil help a leak? Where is it leaking? Click to expand... If I knew where it was leaking I would have fixed it. changing the filters had nothing to do with the leak. thanks for the help!
Sep 16, 2015 / hydraulic leak JD345 #4 W whis Platinum Member Joined Aug 18, 2013 Messages 733 Location al Tractor john deere with your description I believe its leaking at the left front wheel. You really need to tell a little more about it,what area and how bad of a leak
Sep 16, 2015 / hydraulic leak JD345 #5 L Leejohn Elite Member Joined Sep 16, 2007 Messages 4,049 Location Doniphan, Mo. Tractor Kubota L4240, B7800 & BX2660 Where do you think it might be leak? Just what is going on, does something drop or you seeing oil on the floor?
Sep 17, 2015 / hydraulic leak JD345 #6 J_J Super Star Member Joined Sep 6, 2003 Messages 18,952 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST If you have oil on the floor, you should be able to tell where it is coming from. If you are up to it, you can add some fluorescent dye in the tank and shine a black light on everything and you will see where fluid is leaking from. Last edited: Sep 17, 2015
Sep 17, 2015 / hydraulic leak JD345 #7 LD1 Epic Contributor Joined Apr 30, 2008 Messages 22,538 Location Central Ohio Tractor Kubota MX5100 Sorry, I cant help.
