hydraulic leak from steering colum lk 2554
   / hydraulic leak from steering colum lk 2554 #1
wbillbb
pulling the steering wheel was a bear of a job, using a gear puller and trans fluid. there is a rubber seal at the top it cost $41.00, dust seal $68.00, aseal at the base of the column ae 8027e cost $39.00. do not damage the steering shaft it cost $228.00. the colum tube with seals costs $178.00. the bottom o ring was $1.00 a man has to do what a man has to do. ask kioti in NC help yea have fun bill
   / hydraulic leak from steering colum lk 2554 #2
Bill, I'm not sure what all you replaced. Are you saying you DID replace the steering shaft? I suppose you did replace all the other mentioned items?
Was that sarcasm about getting help from Kioti? Sounds like it, but it's not clear.
I'm happy to hear you got it all done. Were you able to tell exactly which of the parts was the culprit, or was it all of them.
Thanks, John
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Modine Shop Heater (A51573)
Modine Shop Heater...
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
