hydraulic leak at lower lift arms on 2240 lohn deere
   / hydraulic leak at lower lift arms on 2240 lohn deere #1
john deere kennyf
Shelby, North Carolina
John Deere 2240
I have a hydraulic leak at lower lift arms at case. It has pin at bottom the bars attach to. Are they seals on this. Can this be a easy fix or is it major problem.
   / hydraulic leak at lower lift arms on 2240 lohn deere #2
:welcome: Repost your ? in the JD owners thread
   / hydraulic leak at lower lift arms on 2240 lohn deere #3
Oil leak is aa relatively easy repair. Drain hyd oil,put L/D control lever under seat in "D",remove draft arms and slide shaft out. Inspect shaft & bushings for wear,R&R seals re-install shaft and draft arms eliminating any side to side motion in shaft with shims. While you have oil drained would be a good time to check cleanliness of sump screen(parts key #30)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
(INOP) 1998 FREIGHTLINER FL70 DUMP TRUCK (A51406)
(INOP) 1998...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A55788)
2017 Ford F-350...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
