Hydraulic Jack Fix ?
/ Hydraulic Jack Fix ? #1
ajmaxham
South Hero, VT
Cub Cadet 582
Harbor Freight Tools -- Central Hydraulics Bottle Jack
Hydraulic oil leaks at the release valve.
groves in release valve sealing surface.
Release valve seal.
I put a piece of heat shrink tubing over the release valve sealing surface. Will this work to repair the jack.
/ Hydraulic Jack Fix ? #3
It might help. Looks like the valve seat is leaking by. Put the jack under a load and see if it holds it. If not the seat is bad.
/ Hydraulic Jack Fix ? #4
I don't think the valve seals on the od it seals at the bottom of the hole. there should be some kind of chamfer on the bottom of the release valve.
/ Hydraulic Jack Fix ? #5
Shrink tube will follow the form and there will still be a slot. Maybe a smaller slot. I'd fill that groove with epoxy and then file it round again. Maybe shrink tubing over the epoxy.
If you store the jack tipped over with the screw-valve pointed up, does the other seal hold oil?
So far it is working. The heat shrink tubing also adds to the OD of the release valve to make a better fit in the release valve seal. I have 3 jack with the same problem. Fixed all 3 with shrink tubing. If the fix does not hold up I will need to find a source for new release valve seals and fill the groove with epoxy as you suggest.
/ Hydraulic Jack Fix ? #7
Why not just put a couple of O-rings in that groove. You will just need to got the diameter of the oring (not OD) the right size to make a tight seal
/ Hydraulic Jack Fix ? #8
I have one like that. It was a 90's Sears Professional. It leaked all the time in storage. After fiddlin' with it for some time, I finally got it to stop, but forgot what I did. Now, I carry it in my truck, but it sits in a steel coffee can.....just in case.
/ Hydraulic Jack Fix ? #9
I had one leaking some and I just took some Teflon tape and taped the screw up good and put it back in and never had any more real problems,
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2015 PETERBILT 579 (A67714)
2015 PETERBILT 579...
2016 Toro ReelMaster 5510-D Commercial Reel Mower (A66734)
2016 Toro...
