Hydraulic issues
/ Hydraulic issues #11
If oil is milky you have water in oil. Also there is a filter screen that needs cleaning at same time you change filter, it may be clogged.
I dealt with hydraulic problems on my 2910i for over a year. Also don't discount seals and o-rings being bad in loader and bucket. I bought the tractor that had been outside at least 2 years, and the owner had used it like it was a 50HP. The hydraulic pump went out, I bought a new one, it was a nightmare to take off and replace, I took a come-a-long and moved the hyd. tube far enough back to get it off and replace it, I wasn't sent new bolts so I assumed I could use the old ones, well the pump blew off in the middle of the field. I took it to machine shop hoping they could repair the threads, they chased them , I got new bolts, put it back on, it blew off again, I decided after talking to my brother , we agreed I couldn't break it, I used metal inserts to repair, not heli coil, I drilled,tapped , inserted them, put it back on, and they are still holding, then I had bucket and loader cylinders rebuilt. This is the last part of my previous problems with hydraulic system. This forum was invaluable too me in guiding and advice. Sally
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
CASE 588H STRAIGHT MAST FORKLIFT (A62129)
CASE 588H STRAIGHT...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2018 Caterpillar 308E2CR (A60462)
2018 Caterpillar...
