hydraulic hoses replacement
   / hydraulic hoses replacement #1
Raw Bone
Jinma 254 tractor with a 140 Koyker FEL . I need to replace the hydraulic hose that has two different size threaded hose ends . Hose coming from pump going to FEL quick disconnect hose connector , what thread sizes ??? The problem is that there is 3 - 4 different types of fittings NPT, JIC , etc.
I went to my local TSC store and all of their pre-made hoses had the same size fittings on both ends. I really didn't want to have to have a hose made up. I was hoping to buy one off the shelf .
   / hydraulic hoses replacement #2
Jinma 254 tractor , 140 Koyker FEL need to replace hydraulic hoses with different size hose ends . Hose coming from pump going to FEL quick disconnect hose connector , what thread sizes ???
Easiest way is to go to any hydraulic shop or tractor sales/service shop and bring hose with you. Alot of ends have to be physically matched. Especially of there are 90s fittings. These have to match bends exactly.
   / hydraulic hoses replacement #3
I read you need threads different than on your current hose. Regardless take the fitting you are trying to match with you. You might be able to find an adapter.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
