Hydraulic Hose
/ Hydraulic Hose #1
theboman
Grayson, KY
Kubota B7500 HST
Well had a hydraulic line on my FEL go bad, leaking around the connector on the joystick. Took it off easy enough and was figuring I had to replace the whole darn thing but Davis Equipment said they should be able to fix that fitting. I didn't realize they could do that!!
/ Hydraulic Hose #2
Yup easy to do as long as it is long enough. check ti our carefully to see why it failed. Often it is do to being pulled too tight and bent. Might get worse if the hose is shortened.
Andy
/ Hydraulic Hose
I thought they was replacing the leaky end, but for $30 the built me a new hose!
The fitting was leaking, 700 hours, so I won't complain.
2019 Dodge Grand Caravan Van (A61569)
2019 Dodge Grand...
2024 GD Yatian LY05A Model T Replica Electric Cart (A61569)
2024 GD Yatian...
New/Unused Receiver Hitch (A61166)
New/Unused...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
378908 (A61166)
378908 (A61166)
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
