Hydraulic Hose
   / Hydraulic Hose #1
theboman
Veteran Member
Grayson, KY
Kubota B7500 HST
Well had a hydraulic line on my FEL go bad, leaking around the connector on the joystick. Took it off easy enough and was figuring I had to replace the whole darn thing but Davis Equipment said they should be able to fix that fitting. I didn't realize they could do that!!
   / Hydraulic Hose #2
Yup easy to do as long as it is long enough. check ti our carefully to see why it failed. Often it is do to being pulled too tight and bent. Might get worse if the hose is shortened.
Andy
   / Hydraulic Hose
I thought they was replacing the leaky end, but for $30 the built me a new hose!
The fitting was leaking, 700 hours, so I won't complain.
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2019 Fontaine Traverse HT T/A 48ft Loyboy Trailer (A49461)
2019 Fontaine...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
Unused Delta Crash...
