Hydraulic hose quick disconnect dirt shield
   / Hydraulic hose quick disconnect dirt shield #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I was annoyed at how much dirt gets on and probably in the quick disconnects. I decided to protect the power take offs with water bottles. I cut off the cap end and just slid them on. Yeah, sometime they fall off (but rarely), but they are real cheap.
I also protect the quick attach fittings by slitting the side of a piece of radiator hose (used is fine) and slipping them over the fittings. These are not perfect, but it helps. I have attached a picture.
Does anybody have a better suggestion?
Oh, on some of the attachements which use the quick attach fittings, I drilled a hole in the water bottle cap, took the fitting off the end of the hose and slipped the hose into the bottle. I also cut the bottom off of the bottle. The bottle can then be slid onto the quick disconnect when in use and slid off to disconnect and connect.
   / Hydraulic hose quick disconnect dirt shield #2
Bob:
You can buy very inexpensive plugs for the hose ends that slide on to the hose over the connector. Then when the hose is not in use, you just plug it in to the connector.
If you look close at the attached pic, you can see them hanging down. (blue thingys)
   / Hydraulic hose quick disconnect dirt shield #3
I use furniture leg end caps. 1" size works well. Got the idea from this forum awhile back.
Even with the plugs (which I use) dirt gets into the sliding disconnect ring. It sounds gritty and could not be good. I like the additional protection of the bottles.
Some think that I am paranoid. I just worry if I am paranoid enough.
   / Hydraulic hose quick disconnect dirt shield #5
"" Got the idea from this forum awhile back. ""
You're welcome!!
"" dirt gets into the sliding disconnect ring ""
"" they are real cheap ""
I use the furniture leg end caps on the small attachment hoses!
The large PTO attachment hoses are just connected together!
For the PTO fittings on the PT, I use 4" x 7" Zip Lock plastic Snack Bags! Cut off one end, then slid the bag over the fitting and its holding tube. With the zipper facing down it slides easily over the retaining bolt. A little hydraulic oil on the outside of the holding tube will hold the bag in place and make it nearly invisible and waterproof!!!!
PS: I always clean the fittings with a quick spray of gasoline before installing the clean caps or bags!!
   / Hydraulic hose quick disconnect dirt shield #6
You may have gotten the idea from my post 10-27-03 post number 332448,glad someone got something useful from my posts.
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2018 GENERAC MAGNUM MMG251F1 PORTABLE GENERATOR (A52706)
2018 GENERAC...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
2019 Chevrolet Express 2500 Cargo Van (A55788)
2019 Chevrolet...
