hydraulic hose question
/ hydraulic hose question #1
10acreheaven
st.Louis mo
bolens g174
I'm upgrading a log splitter I built last year to hydraulic. I'm going to run it off my tractor (bolens g174) front loader. It has 1/4" hoses. I have a 3" cylinder with 1/2" ports. I know its not going to break any speed records, but what size hoses should I get for it. It will connect to my front loader controller with 1/4 quick connects. Thanks for the help!
/ hydraulic hose question #2
If the cyl has 1/2 in ports, why not use 1/2 in hose .
Didn't know if there would be a problem going to a 1/4 quick connect at the loader controller
/ hydraulic hose question #4
If 1/4" is what is on the valve pump is low enough to get minimal restriction with 1/4" hose, but I tend to error to a larger size just to be safe. Not much difference is price from 1/4". 3/8", or 1/2" hose. Could use 1/2" with 1/2 to 1/4 reducer bushing at the QD. Or use 3/8" hose, have it custom made and put 1/2" fitting on one end and 1/4" fitting on the other and not need to buy reducer bushings.
/ hydraulic hose question #6
You can do all the things above, but I'm not sure how much benefit you get from increasing the hose size if you are still using 1/4" quick disconnects. Assuming you are using 1/4" ag couplers (aka Pioneer 4000 series), your maximum flow rate won't exceed 3 or 4 GPM, regardless how big a hose you use.
Yeah I'm thinking 1/4 will be fine too, I just didn't want to restrict flow. But like you said I'm like right at my GPM with 1/4" lines so that is good. Would I be hurting anything using bigger lines? Only reason I ask is my farm store has a lot of 3/8 & 1/2 to choose from
/ hydraulic hose question #8
What is the actual port size on the pump outlet?
Someone might have used 1/4 hose and fittings to save some money.
/ hydraulic hose question #10
According to tractordata the bolens you have is the same tractor as an iseki 1500. Which has a total pump output of 2.7GPM
You will gain nothing by going with larger hoses.
With a 3" cylinder, assuming 24" stroke, if you are getting the full 2.7gpm, you will have a 16 second extend time. Retract speed would depend on rod size.
And the way it is listed as "total pump output" makes me question weather you are even getting 2.7. of if some of that is diverted for power steering use or a second pump and they total the two to get the "total"
/ hydraulic hose question #12
If you go to a larger hose diameter, you may starve the pump of oil. 1/4" hose will be fine to accomplish what you need. Max I would suggest is 3/8" hose.
/ hydraulic hose question #13
By my calls your fluid velocity with 1/4 inch hose will be less than 18 feet/minute which is fine. Don't really get concerned until fluid velocity gets over 20 ft/min.
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
Case IH 181 Rotary Hoe (A66408)
Case IH 181 Rotary...
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A65563)
2011 Dodge Charger...
4" Makita Disc Grinder (A62613)
4" Makita Disc...
2026 Electric Tricycle (A64194)
2026 Electric...
Unverferth Perfecta II (A64126)
Unverferth...
