Hydraulic Hose markers
   / Hydraulic Hose markers #1
Dataway
Greenfield TN
Ford 1715, BX2200
My Kubota snow thrower has quick disconnect hose for the hydraulics ...with small spiral plastic rings of different colors to mark the positions .... anyone know where these can be purchased ... mine are gone and I'm tired of hooking it up the wrong way every winter :)
Thanks.
   / Hydraulic Hose markers #2
I use colored wire tires for hose identification. Inexpensive & readily available.
   / Hydraulic Hose markers #3
colored zip ties | eBay.
There's four hoses? If so put a male on the tractor to a corresponding female on the blower and opposite for the other. Best way is to have one long hose on each, that way when you're done, you can couple the couplings together on the blower and on the tractor to keep out dirt..................Mike
   / Hydraulic Hose markers #4
When I see colored tie wraps (zip ties) on sale, I buy them just for this purpose.
I was always told that if you dig deep enough you will hit china, so generally a yellow zip tie will go on the bottom. Is that racist?
   / Hydraulic Hose markers #5
...I was always told that if you dig deep enough you will hit china...
Not even close...the deepest man made hole (below sea level) ever dug/bored is only a few thousand feet deeper than the deepest naturally occurring spot in the ocean depths...
To dig through earth if it was possible would take a hole one thousand times deeper...
   / Hydraulic Hose markers #6
The Aliens that live there (in the hollow Earth) might complain if you suddenly pop out their ceiling.
Anyway, I thought the deepest hole was Mels hole.
   / Hydraulic Hose markers #7
Mels hole is a myth...never existed... Art Bell was scammed (more than once)...
   / Hydraulic Hose markers #8
Then, where did all the stuff thrown down there go?
   / Hydraulic Hose markers #9
That's what I use. If you want the rings, Tractor Supply generally has them. They have them labeled as chicken identification ankle bracelets.
Aaron Z
   / Hydraulic Hose markers #10
Failing having coloured tie-wraps (zip-ties), I use a corresponding number of 'wraps' on both sides of the connections...
0 (none), 1, 2, 3.
That way, even if the colours fade (or it's dark) you'll reduce the risk of getting it wrong.
UNUSED CHERY INDUSTRIAL 7' - 10 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
(APPROX 20) 2" X 3" X 49" TUBING (A51247)
(APPROX 20) 2" X...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2007 Chevrolet Tahoe SUV (A51694)
2007 Chevrolet...
