hydraulic hose holder
/ hydraulic hose holder #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
So I have 1 rear remote and that remote controls the front grapple. Rear back hoe dump trailer wood chipper and wood splitter. Often I disconnect the 2 lines from the grapple when I require another implement hooked up. Then I don't have a good place to store the lines and the next time they are covered on mud , dirt and dust. Is there a item like a dummy plug to hold and support the hoses?
Preferable something that's not going to open the hose ends so the oil all leaks out?
/ hydraulic hose holder #2
They make rubber male and female plugs for the QC ends but most just connect the male and female QCs together to protect both sides. From there it would seem you could do anything from a zip tie to a full on bracket.
If you wanted to make a mount and leave the hoses in place AND add a set of QCs they make “bulkhead” fittings that will mount to a hole drilled in say steel plate.
/ hydraulic hose holder #3
Get some old female quick couplers and gut them so they will not open your hose ends. Then find a place to mount them.
/ hydraulic hose holder #5
tractor supply has the dummy plugs
/ hydraulic hose holder #6
Another option 5089L209 Hose Hanger made by Wallenstein. Show in the attached pic. You may need to zoom in. Modify and mount 20180707_173310.jpgas needed. Later
/ hydraulic hose holder #7
Am I the only one who just hooks them (male and female QDs) together to keep the ends clean, connected and with no possibility of one side building up pressure?
Or am I missing something?
/ hydraulic hose holder #8
If I dont do that with my backhoe, I'm not getting it connected without cracking a fitting loose to let out pressure.
/ hydraulic hose holder #9
Nope. It’s in the tractor gospel. Anyone that does otherwise hasn’t reached the wisdom level.
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
2014 Ford Taurus Sedan (A59231)
2014 Ford Taurus...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
2000 Peterbilt 378 Tri-Axle Dump Truck (A59230)
2000 Peterbilt 378...
