Hydraulic hose help
/ Hydraulic hose help #2
I think we all need just a little more info...:confused3:
Sorry I thought I got it all on here.let me start over. First I blew a seal on the bucket of my loadee on b8200 e. Ok i replaced it and then loader wouldn't go up or curl. I cleaned control valve .then hydraulic shop said hydraulic block valve was bad. I replaced it. Now I hope I have a hose crossed somehow. Thought I had them correct but so much for thinking anyway now the only way to get bucket to work is tty o crack one of the fittings while operating control. I need a hose digram. Any help would be appreciated so much.
Ok i finally got it figured out somewhat. First I traced all my lines and made sure they were in right place then stsrted adjusting relief valve on loader control valve. Lo and behold it started working. Thank you Jesus. I had to run adjustment screw in further than it was originally also now when bucket is curled all the way or lifted all the way up I am getting a whining noise. Is this the pump cavitating or is it the relief valve
/ Hydraulic hose help #6
You raised the relief pressure without using a pressure gauge? :eek:
I would check the pressure ASAP.
I only turned it in very small increments until loader started working. I am going to try to check pressure this weekend but I did use tractor for about an hour moving manure pile that had accumulated behind barn while tractor was down
/ Hydraulic hose help #8
Kubota is crazy proud of the old loader control valve. Hope you have yours fixed.
Yes they are. I'm a lot closer than I was last week so I feel better about it. Just for the hydraulic block valve they wanted 789.00 and only 2 in the US. Got a used one shipping included 118.00. Thanks
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2011 Ford Explorer (A64127)
2011 Ford Explorer...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
