Hydraulic Hose Connectors
   / Hydraulic Hose Connectors #1
DIRTCUTTER
New Mexico
CK30 HST
This morning I spend a good 45 minutes and thats fast for me trying to get the hoses on the my BH connected to hoses on the tractors. Is there a different type of connector other than the push in snap type that is easier to connect. I have tried bleeding the hoses and its still very difficult.
   / Hydraulic Hose Connectors #2
I found the only easy way is to put the position select lever (A-N-B) in Nuetral and to keep moving the BH levers to release the pressure. Then they pop right in. I don't think people realize that the pressure is in the lines on the BH and not the tractor. If you keep moving the levers on the BH the pressure will go down.
   / Hydraulic Hose Connectors #3
The other trick with these connectors is to take the male side and put a cloth over it before giving it a firm tap with a hammer. That often releases pressure. A clean wooden dowel can fit inside the female connector and press the pin there to release pressure too.
I find that if I need to struggle for more than 30 seconds connecting these things that there is likely still pressure in one side or the other.
Island, I tried that. Now I understand there might be a tool out there that helps to connect. Thanks
   / Hydraulic Hose Connectors #5
Make sure you post a review of said tool if you find it.:)
   / Hydraulic Hose Connectors #6
I use a caulking gun to make up difficult connections.
Get a large washer where the center hole will fit behind part of one fillting, and the outside will fit in the front end of the caulking gun. Make two cuts with a hacksaw so the washer is in a "U" shape that will fit over one fitting and be caught in the front of the caulking gun. Catch the rear of the other fitting with the plunger of the caulking gun and you will find that you can apply a lot more force this way than with hand power alone.
   / Hydraulic Hose Connectors #7
Pioneer has new ends out that allow you to hook under pressure.
2011 Ford F250 Pick Up (A55272)
2011 Ford F250...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2012 International Prostar (A56438)
2012 International...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2012 Dodge Grand Caravan Van (A56859)
2012 Dodge Grand...
