Hydraulic Hose Collar Issue
   / Hydraulic Hose Collar Issue #1
dmfahie
Limington, Maine
J.D. 2305
Hello. I am attaching my loader to my 2305. I am having issues with the Yellow & Grey collars. I put the hose in, but the collar will not retract and the hose cant stay in place? The other hoses did not have an issue. Any advice? Seems like a no brainer!?!?:confused:
   / Hydraulic Hose Collar Issue #2
Likely you have the "pressure in the hose" problem, and need to wrap the male end with a rag and press the tip against something hard (carefully as oil will squirt out under some pressure). After the pressure is relieved, then I expect you will be able to make the connection. Just be sure the collar does slide back as rarely do they get sticky and balk.
http://www.tractorbynet.com/forums/...ng/236593-cant-connect-quick-hd-couplers.html
Beenthere, AWESOME. You nailed it. My son and I were out there 60/90 minutes earlier. With your advice we nailed in in 5 minutes and we were off moving snow banks! Thank You very much, great forum.
Devin
   / Hydraulic Hose Collar Issue #4
That is good to hear, and thanks for the feedback to the forum.
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
23222 (A50323)
23222 (A50323)
Hyster H225E (A47384)
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2022 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2022 Allmand Bros...
