Hydraulic Hose Collar Issue
   / Hydraulic Hose Collar Issue #1
dmfahie
Limington, Maine
J.D. 2305
Hello. I am attaching my loader to my 2305. I am having issues with the Yellow & Grey collars. I put the hose in, but the collar will not retract and the hose cant stay in place? The other hoses did not have an issue. Any advice? Seems like a no brainer!?!?:confused:
   / Hydraulic Hose Collar Issue #2
Likely you have the "pressure in the hose" problem, and need to wrap the male end with a rag and press the tip against something hard (carefully as oil will squirt out under some pressure). After the pressure is relieved, then I expect you will be able to make the connection. Just be sure the collar does slide back as rarely do they get sticky and balk.
http://www.tractorbynet.com/forums/...ng/236593-cant-connect-quick-hd-couplers.html
Beenthere, AWESOME. You nailed it. My son and I were out there 60/90 minutes earlier. With your advice we nailed in in 5 minutes and we were off moving snow banks! Thank You very much, great forum.
Devin
   / Hydraulic Hose Collar Issue #4
That is good to hear, and thanks for the feedback to the forum.
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2016 BOBCAT S770 SKID STEER (A52705)
2016 BOBCAT S770...
