Hydraulic hookup on bush hog
   / Hydraulic hookup on bush hog #1
dmaxxx21
none
john deere
I have a 15ft bush hog with 3 hydraulic lines but the tractor only has 2 remotes, how do I need to hook it up for either lifting both wings at the same time or individually plus raising the cut height, my other tractor had 3 remotes so it was not a problem, any help would be appreciated.
   / Hydraulic hookup on bush hog #2
You can tee the 2 hoses together that raise/lower the wings. Downside is both wings will raise simultaneously unless one side has less resistance.
I thought it would be something like that, How do I tee the 2 together? What part do I need? Thanks for the help.
   / Hydraulic hookup on bush hog #4
You need to determine the type and size of the fittings currently used, as in the threads/type of the hose ends and male quick coupler.
If you wanted to control the wings separately you could put a ball valve (high pressure) in each wing line and shut off the one you did not want to raise. That would be an expensive way to go, but cheaper than adding a third remote.
   / Hydraulic hookup on bush hog #5
You could hook up a diverter/selector valve on the tractor. Run lines from 1 remote to the selector valve, then coming out of the selector valve put in remote coupler for both wings. One wing would work as normal, acitvate the selector valve and move your remote lever to run the other wing. Selector valve could be manual or electric depending on how convenient you want or $ you wnat to spend.
   / Hydraulic hookup on bush hog #6
Another option would be an electrically controlled Fasse valve.
   / Hydraulic hookup on bush hog #7
Ask questions and plan before you go designing stuff.
Do you plan on having one side down and the other side up? If not, use a T-fitting to put both sides working in unisyn and you're good to go. If you need to have one side or the other down, anything from diverter valves to a simple "on/off" on each side could do the trick for you.
Raising and lowering the wings together would be fine and sounds the simplest way to do this,so can I just get a t fitting at tsc or where? Thanks for the help.
   / Hydraulic hookup on bush hog #9
Yes TSC should have the fittings.
I believe I found what needed so I will try it out this week, thanks for all your help.
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
